What is this and why is it dripping?
Banjoblue
Post by Banjoblue » Mon Mar 17, 2014 8:58 am
There's a drip from the tube at the top of the picture, it looks like a square plastic plug sealing the end of a pipe. Anybody know what it is?
Gasy
Re: What is this and why is it dripping?
Post by Gasy » Mon Mar 17, 2014 9:09 am
Do you have a conversion fitted?
If so might of had rear heater / air on removed and that pipe is what used to feed one of them
Post by Northern Bongolow » Mon Mar 17, 2014 9:08 pm
if you mean the pipe thats bent back on it self and secured via the plastic hook, thats the end of the bleed pipe.
sometimes the clip eats its way into the pipe wall, or can get damaged rubbing on something, it looks like its been routed in an odd manner. examine it carefully, if its to be removed to be fixed or shortened seek advice as you may have to bleed the coolant system if you are not careful.
Driver+Passengers
Post by Driver+Passengers » Mon Mar 17, 2014 10:17 pm
http://mazdabongo.wikispaces.com/Parts
Engine bay (nearside), part (3). That's the bleed hose - is that what you're looking at? ie not what your finger is pointing to...?
Image Image
Post by Northern Bongolow » Tue Mar 18, 2014 9:44 pm
which engine is it ?, it looks petrol, not that it matters it still looks like the bleed pipe.
Post by Simon Jones » Tue Mar 18, 2014 10:00 pm
That'll be a V6 then. There should be a plastic clip on the rocker cover which keeps it up out the way. The end with the bung can neatly be cable tied to the wiring loom.
Post by Northern Bongolow » Thu Mar 20, 2014 6:45 pm
bit scruffy that engine bay :roll: .
looks like its routed the same as simons pics. :)
Post by Bob » Thu Mar 20, 2014 8:37 pm
[quote="Northern Bongolow"]bit scruffy that engine bay :roll: .
:D :D :D
Post by Simon Jones » Thu Mar 20, 2014 10:34 pm
Yes, there's quite a bit going on there. Got even more pipework at the top end for the LPG:
Banjoblue
Post by Banjoblue » Mon Mar 24, 2014 11:10 am
Thanks all - that's really helpful.
