What is this and why is it dripping?
Re: What is this and why is it dripping?
Do you have a conversion fitted?
If so might of had rear heater / air on removed and that pipe is what used to feed one of them
if you mean the pipe thats bent back on it self and secured via the plastic hook, thats the end of the bleed pipe.
sometimes the clip eats its way into the pipe wall, or can get damaged rubbing on something, it looks like its been routed in an odd manner. examine it carefully, if its to be removed to be fixed or shortened seek advice as you may have to bleed the coolant system if you are not careful.
- Driver+Passengers
http://mazdabongo.wikispaces.com/Parts
Engine bay (nearside), part (3). That's the bleed hose - is that what you're looking at? ie not what your finger is pointing to...?
which engine is it ?, it looks petrol, not that it matters it still looks like the bleed pipe.
That'll be a V6 then. There should be a plastic clip on the rocker cover which keeps it up out the way. The end with the bung can neatly be cable tied to the wiring loom.
bit scruffy that engine bay
looks like its routed the same as simons pics.
[quote="Northern Bongolow"]bit scruffy that engine bay
Yes, there's quite a bit going on there. Got even more pipework at the top end for the LPG:
Thanks all - that's really helpful.
