ignition barrel
kpautos
ignition barrel
Post by kpautos » Wed Mar 05, 2014 5:15 pm
hi everyone just a quick question,
can the ignition barrel be removed by turning the key to say position two and pressing a button on the side, i cant seem to get this one to play ball but it may not come apart like that if you know what i mean.
sorry if its elswhere on the forum allready
thanks, kirk
Gasy
Re: ignition barrel
Post by Gasy » Wed Mar 05, 2014 6:14 pm
I've no idea
But there's a guy on here who can cut keys and make new ignition barrels from just the number on your original key
Give him a PM
Name on here is hypno211
Or tom
Does a good job I had him cut a new key works fine
Had been back and forwards to local key cutters trying to get there's to work never did.
jimmo62
Re: ignition barrel
Post by jimmo62 » Wed Mar 05, 2014 10:48 pm
the workshop manual for the 2.5TD says you have to remove the whole key cylinder set by making a groove in the head of the shear bolt with a chisel and then unscrew the bolt to remove the key cylinder. To replace you need a new shear bolt.
kpautos
Re: ignition barrel
Post by kpautos » Thu Mar 06, 2014 10:28 am
yes there are two shear bolts so its looking like the whole unit has to be changed, thanks for your replies, regards, kirk
kpautos
Re: ignition barrel
Post by kpautos » Mon Mar 10, 2014 11:35 am
all done, thanks for your help
