mileometer
jamesythe3rd
mileometer
Post by jamesythe3rd » Sun Feb 16, 2014 5:09 pm
I bought my bongo in 2012 and fingers crossed, other than a radiator and an alternator, it's been running pretty well. There does however appear to be a problem with my odometer calibration.
I had my suspicions after a holiday to Cornwall later that year as I thought the total mileage to be steep but just put it down to not knowing the distances involved. It was pretty much confirmed following a trip to France last year, my odometer is clocking up at nearly double the actual mileage despite the speedometer showing an accurate speed.
Does anyone know how and where I could get my ODO properly calibrated and further, given that I can confirm my mileage at time of purchase I would be looking to get my bogus miles taken off the clock if possible.
I have gone back to the seller in Dunfermline but they have taken the somewhat disappointing stance of completely ignoring all contact including a personal visit.
Thanks in advance.
J
Re: mileometer
Post by Muzorewa » Sun Feb 16, 2014 5:30 pm
It's probably reading the distance in km :wink:
Re: mileometer
Post by francophile1947 » Sun Feb 16, 2014 7:12 pm
Muzorewa wrote:It's probably reading the distance in km :wink:
As indeed do most of them :wink:
Unless your speedo goes up to about 180mph, you have a conversion faceplate fitted (which is very common) and your odometer will still read in kilometres 8)
scanner
Re: mileometer
Post by scanner » Sun Feb 16, 2014 7:34 pm
You also need to make sure your MOTs record the fact that the distance on them is in Km's not miles. otherwise the value could be badly affected.
The only way I know to re-calibrate the odometer is to fit a conversion chip. Some people have problems with them affecting other electrics - some don't. Mine has a chip and touch wood no problems in over 6 years now.
http://www.ebay.co.uk/itm/Speedo-speedo ... 0258508684
Re: mileometer
Post by rita » Sun Feb 16, 2014 8:05 pm
I can imagine that you were very happy with the fuel consumption.
scanner
Re: mileometer
Post by scanner » Sun Feb 16, 2014 8:12 pm
rita wrote:I can imagine that you were very happy with the fuel consumption.
Fuel consumption isn't any better, the "miles" per gallon is higher - but unfortunately everywhere is 60% further away.
Re: mileometer
Post by Simon Jones » Sun Feb 16, 2014 10:45 pm
You could fit a speedo chip but that would mean changing the dial back to standard. Alternatively, track down a GA5R speedo from a Mazda 323 or 626 (I think), set the odometer to the correct miles equivalent of your km readings and then it will be fully in miles.
nth
Re: mileometer
Post by nth » Sun Feb 23, 2014 12:14 pm
scanner wrote:You also need to make sure your MOTs record the fact that the distance on them is in Km's not miles. otherwise the value could be badly affected.
Current MOT Certificates don't specify if its miles or KM's, it just says odometer reading then the number.
95 2.5d 4WD AFT
Re: mileometer
Post by rita » Sun Feb 23, 2014 1:05 pm
Correct, they use Odometer and History readings on the MOTT Certificate.
Re: mileometer
Post by Simon Jones » Sun Feb 23, 2014 2:22 pm
It changed at some point between 2012 and 2013:
scanner
Re: mileometer
Post by scanner » Sun Feb 23, 2014 4:28 pm
As Simon says the DEFAULT is Miles - you have to tell them it is km's and they add km's, otherwise the number is meaningless.
jamesythe3rd
Re: mileometer
Post by jamesythe3rd » Wed Feb 26, 2014 9:27 pm
Thank you all for the responses, seems so very obvious now, wasn't aware they could overlay the ODO facia like that.
Every day is a school day!
laters :D
