Year 2000 Bongo Radio Hack
Moderator: Ian
Astroman
Post by Astroman » Tue Nov 26, 2013 4:44 pm
Is it possible to hack the radio so the channels are within the same band we use in the UK? Or do most people just swap out the radio? I could swap the radio I guess, but I kind of like it with its little display and picture of Tokyo Tower.
wonkanoby
Re: Year 2000 Bongo Radio Hack
Post by wonkanoby » Tue Nov 26, 2013 4:48 pm
swap it
stuc
Post by stuc » Tue Nov 26, 2013 4:53 pm
You can fit a band expander which will give you more frequency to play with.
Just do an ebay search theres loads.
http://www.ebay.co.uk/itm/FM-Radio-Band ... 2654wt_966
wonkanoby
Post by wonkanoby » Tue Nov 26, 2013 5:19 pm
but they dont give full uk range best im aware
Post by g8dhe » Tue Nov 26, 2013 11:47 pm
And they become crap radios with all sorts of interference and cross modulation ! Swap it out.
stuc
Post by stuc » Thu Nov 28, 2013 10:07 pm
wonkanoby wrote:but they dont give full uk range best im aware
88-108mhz which is what my current set gives and I can get all stations I need. I had a band expander on my first Bongo and it worked as good as any other radio. Some people can't afford to just swap it for an expensive one. Its a cheap alternative and does till you can afford a decent one.
Astroman
Post by Astroman » Sun Dec 01, 2013 11:06 pm
Cheers, will give expander a try first.
Return to “Pimp My Bongo”
