I've got a noise
Sparticus
I've got a noise
Post by Sparticus » Sun Nov 03, 2013 9:10 pm
When it's quiet (no wife or children in the car) I keep hearing a clicking noise over the passenger side, whilst I'm driving. It's an intermittent clicking noise. Sounds like it's coming from the passenger door. My thoughts are that it's a solenoid , don't know why, not really sure what a solenoid sounds like, but that's my guess.
Any thoughts? is there a solenoid for the locking of the door? Could that click every now and again for no apparent reason?
ps
spelt it 'soliniod' to start with, spell check suggested 'Mussolini'!
Reality looks interesting from this distance.
Re: I've got a noise
Post by Simon Jones » Sun Nov 03, 2013 9:29 pm
If it was the central locking solenoid you'd see the lock button moving up and down. I find both our lock buttons tend to rattle a bit when driving, so I find the solution is to lock the doors when we set off. Try getting a passenger to apply pressure to different areas of the door while you're driving to see if they can identify any change in sound.
Post by Bob » Sun Nov 03, 2013 9:40 pm
Italian hiding in the panel?
Sorry. :oops: Had to. :D
Post by g8dhe » Sun Nov 03, 2013 11:07 pm
There is a relay used in the Climate Control mounted above the nearside front wheel ? It bypasses the relay for Max. fan power could it be that operating ?
Sparticus
Post by Sparticus » Mon Nov 04, 2013 8:59 am
Thanks, things for me to check.
The locking button is not moving, I had tried locking the doors, didn't make any difference, so it's looking like either the climate control relay or the Italian.
Post by rita » Mon Nov 04, 2013 10:46 am
Do you have a BMW clock fitted.
Post by g8dhe » Mon Nov 04, 2013 11:11 am
Is it a V6 ? or petrol ? There is a fuel purge solenoid of some sort under the passenger seat that operates occasionally as well.
Its 18-740 here http://lushprojects.com/bongopartsmk2/c ... o=.html#19
Sparticus
Post by Sparticus » Mon Nov 04, 2013 11:57 am
No clock fitted.
It is a petrol V6 with an lpg conversion
New Forest Terrier
Post by New Forest Terrier » Mon Nov 04, 2013 12:56 pm
On the V6 there is a carbon canister in the engine bay on the passenger side which can click. Something to do with the egr I think. No more data than that. I came across this on the forum ages ago and remembered in case of any unexplained noises.
Tweeky
Post by Tweeky » Mon Nov 04, 2013 2:43 pm
Hi. I've also got a V6 with LPG and have clicking noises from passenger side.
If you watch the LPG changeover lights, the first click occurs when the engine is at temp for gas running . ( I think its when the flow is switched on to the vapouriser). The second click occurs just before the engine changes over to run on Gas. (Flow to Gas Injectors)
May not be your problem, but this may be the cause if its not continuous clicking
Post by Simon Jones » Mon Nov 04, 2013 10:31 pm
Try switching back to petrol and see if it goes away. On mine, I can just hear the injectors clicking, so you might have a noisy one on the left hand side. A piece of thin wood, or a long screwdriver makes a good stethoscope to listen to different parts of the engine to help trace the source.
The canister mentioned above is the round thing at the bottom of this picture. On the other half's Golf, the solenoid on the canister clicks all the time like a noisy tappet.
Sparticus
Post by Sparticus » Mon Nov 04, 2013 10:46 pm
Sorry, I've not had a chance to go out in it for the last few days. So I have not had a chance to check any of your suggestion, but come Wednesday, I'll be having a good look.
The click doesn't seem to happen all the time, and usually at least a minute or so apart. I think it's worse over rough ground.
Sparticus
Post by Sparticus » Sun Nov 10, 2013 7:15 pm
Clicking sound definitely is coming from the passenger door. Happens whether locked or unlocked. Bongo at under-sealers for a few days now, but next stage is to remove door lining and drive round for a bit..
