foglights
Moderator: Ian
the1andonly
foglights
Post by the1andonly » Sat Oct 26, 2013 11:12 pm
i've not factory fog lights (neither has bongo)
so bought some ring fog lights to fit the hole, looked at bongo and searched forum
still got questions
1 physical connection:
Now as to physicaly mounting them. There is no solid metal work to mount to.
Do i just drill a hole in the plastic work, hanging the assembly from the roof of the lamp orrifice or some other clamping method. the sides seem more solid
2 electrical:
I have 3 relays, hidden wiring on rhs by steering wheel include 2 plugs one with red/white wire tother with black yellow
do i need an origional switch with existing loom or how to use a 3 wire switch (iluminated as supplied with kit)
do i forget wiring loom and do it fresh
lancyman
Re: foglights
Post by lancyman » Sun Oct 27, 2013 4:15 pm
I have the same problem re not having any
Fog lights on the front. What lights did you buy
Please, and where from? Thanks in advance.
the1andonly
Re: foglights
Post by the1andonly » Sun Oct 27, 2013 5:43 pm
THese from Halfords
http://www.halfords.com/webapp/wcs/stor ... yId_272450
currently includes relay, switch, wire and fuse
mounting I'm not sure thats why asking for advice
stuc
Re: foglights
Post by stuc » Mon Oct 28, 2013 10:15 pm
I used the ring ones on my last Bongo, they fitted fine i just made some brackets and used the small holes in each corner of the foglight hole on the bumper to fasten them on.
the1andonly
Re: foglights
Post by the1andonly » Tue Oct 29, 2013 8:09 pm
thanks
stuc
thinking about 2 straight plates corner to corner in X pattern.
Re: foglights
Post by Simon Jones » Tue Oct 29, 2013 9:51 pm
Ignore the red lines, but the original brackets can be seen in the middle:
The larger outer holes fit to the bumper while the smaller ones were for the screws that went into the rear of the lamp. You could just get a piece of black plastic, drill 4 holes to suit the bumper mounting points and then fit the lamp to the front.
Return to “Pimp My Bongo”
