Hi All
I am hoping that someone can offer advice as I turn to the right I sometimes get a clunking noise and the steering appears to go light any suggestions it does not happen all the time?
Steve
Powys Wales
Bang
Re: Bang
Tried opening the window? could be you are hitting your head against the window ?
Sorry! Somebody far cleverer than me will come up with a helpful answer.
Chris with BertieB
- Simon Jones
Re: Bang
Can you determine roughly where noise is coming from? Could it be one of the universal joints in the steering column which is worn/needs greasing, or something external in the steering / suspension components. Try jacking the front up & turning the wheel from lock to lock & having a goo look & listen.
Anyone remember the Allegro where swivel joints would fail & the whole wheel would fall off!? I seem to recall someone on here had something similar on their Bongo & quite a lot of damage was done. It's probably worth getting to the bottom of the problem before it deteriorates.
Re: Bang
oooooh yes
that was when driving was interesting, could'nt even let the steering slip though your hand when coming out of a corner, and sloppy hydroelastic suspension. great fun
Got a Bongo for the Wife, Best trade-in ever
Re: Bang
was it the one where the wishbone pivot snapped off and the whole lot spun around simon.Simon Jones wrote: I seem to recall someone on here had something similar on their Bongo & quite a lot of damage was done.
i must admit im struggling to come up with something that would knock like described above, could it be that the strut top is loose, there are 3 little studs/nuts and a bearing up there, the nearside tends to seize the bearing then collapse.
or check the mountings on the steering rack to cross member.
- Simon Jones
Re: Bang
Thanks Ady, I was trying to remember exactly what happened. Here's the thread:
http://igmaynard.co.uk/bongo/forum/view ... ge#p570876
Photos here:
http://s221.photobucket.com/user/bongom ... t=3&page=1
Photos here:
