Night heaters
AnnaandAde
Night heaters
Post by AnnaandAde » Mon Oct 14, 2013 8:10 pm
Can I get a night heater for a bongo?
Gasy
Re: Night heaters
Post by Gasy » Mon Oct 14, 2013 8:23 pm
Yes that would be ok
Gixermark
Re: Night heaters
Post by Gixermark » Mon Oct 14, 2013 9:11 pm
AnnaandAde wrote:Can I get a night heater for a bongo?
Just finished fitting a propex system. Cost £430 from www.vwheretage.co.uk for the complete kit.Runs off the gas bottle supplying the hob, easy to fit if your ok with DIY! Problem I had ( as have many others on here with fully converted bongos ) the hole at the rear where you hide the bottle is only big enough to allow a camping gaz sized bottle, being butane this is no good when very cold ...propane ( red bottles ) are required. Took the rear section off, cut the wardrobe floor in half and batterned back up to allow for a false floor ....I'm now able to 'drop' a 3.9kg bottle in from the top rather than through the rear door but this allows us to use our bongo in colder weather.
Really pushes the heat out ....The propex heater that is!
Re: Night heaters
Post by Simon Jones » Mon Oct 14, 2013 11:32 pm
Do a search on here for Eberspacher or Webasto. There are also 2 factsheets in the members area.
Alison01326
Re: Night heaters
Post by Alison01326 » Wed Oct 16, 2013 7:15 pm
They make very good day heaters too!
We had a Webasto fitted about four years ago and it was worth every penny, from being able to go to bed warm and wake up warm, to warming up after a chilly walk or standing around watching our son playing rugby in bitter conditions (made a nice warm place for him to change, too!)
Alison
AnnaandAde
Re: Night heaters
Post by AnnaandAde » Thu Oct 24, 2013 7:21 pm
Thanks guys.
