Night heaters
Moderator: Doone
AnnaandAde
- Junior Bongonaut
Night heaters
Can I get a night heater for a bongo?
Re: Night heaters
Yes that would be ok
Re: Night heaters
Just finished fitting a propex system. Cost £430 from www.vwheretage.co.uk for the complete kit.Runs off the gas bottle supplying the hob, easy to fit if your ok with DIY! Problem I had ( as have many others on here with fully converted bongos ) the hole at the rear where you hide the bottle is only big enough to allow a camping gaz sized bottle, being butane this is no good when very cold ...propane ( red bottles ) are required. Took the rear section off, cut the wardrobe floor in half and batterned back up to allow for a false floor ....I'm now able to 'drop' a 3.9kg bottle in from the top rather than through the rear door but this allows us to use our bongo in colder weather.AnnaandAde wrote:Can I get a night heater for a bongo?
Really pushes the heat out ....The propex heater that is!
Re: Night heaters
Do a search on here for Eberspacher or Webasto. There are also 2 factsheets in the members area.
Alison01326
Re: Night heaters
They make very good day heaters too!AnnaandAde wrote:Can I get a night heater for a bongo?
We had a Webasto fitted about four years ago and it was worth every penny, from being able to go to bed warm and wake up warm, to warming up after a chilly walk or standing around watching our son playing rugby in bitter conditions (made a nice warm place for him to change, too!)
Alison
AnnaandAde
- Junior Bongonaut
Re: Night heaters
Thanks guys.
