I need to get access to drill out manifold stud, and want to take the alternator off. I've taken off the adjuster and the big nut/bolt at the base where it pivots, so it swings on it's pivot comfortably but I can't seem to take it right off....where it pivots is there a sleeve that the bolt runs through which needs to be drifted out or what?
Rob
How do you take the alternator off?
- Simon Jones
- Bongonaut
If its any help, I managed to drill out the stud without removing the alternator-I used an extension bar in the drill, which had to be positioned hard against the outside frame, with the bar passing close to the alternator. Also, I found the stud material was extremely hard, only cobalt drill bits would touch it!
It wasn't me, Guv; a big boy done it and ran away!
