Window motor
Shirley
Window motor
Post by Shirley » Mon Jul 29, 2013 12:52 pm
Hi, I am just waiting for funds to convert my Bongo and the window motor has broken. Has anyone got the information to get a replacement part, please. :?
mikeWalsall
Re: Window motor
Post by mikeWalsall » Mon Jul 29, 2013 1:10 pm
Maybe better do do a double check, as it's generally the wires that come out of the door jamb break .. or occasionally the (expensive) widow switch fails ..
Shirley
Re: Window motor
Post by Shirley » Tue Jul 30, 2013 10:18 am
(expensive) widow switch fails .. :( :( :( I think that is the problem, how expensive... ?
Also do you know how to get one/
S
mikeWalsall
Re: Window motor
Post by mikeWalsall » Tue Jul 30, 2013 10:43 am
I would suggest you are 100% certain what the problem actually is .. before paying for something that may it isn't ..
Bongo and compatible second hand switches are available from scarp yards ..ebay etc:
If you need a new one expect to pay £135 - £185 for one ..
http://www.mazdabongo.com/catalog/elect ... all-models
http://www.bongobits.com/index.php?main ... ex&cPath=3
http://www.igmaynard.co.uk/bongo/mercha ... m#Interior
Re: Window motor
Post by Muzorewa » Tue Jul 30, 2013 11:36 am
As above, check the loom between body & door, probably not where it goes through the grommets but at the bottom of the "U" as it's distorted onto the cable clamp on the edge of the door :wink:
You'll have to cut the outer sheath away and hopefully the problem will then be self-evident.
Unless it's the passenger door and you've inadvertently switched that window off on the driver's door controls.... :wink:
timjonz
Re: Window motor
Post by timjonz » Thu Aug 01, 2013 8:36 am
My switch finally broke yesterday after a period of intermitant failure.
So I removed the switch unit to find that the problem is that the plastic peg on the slider switch on the circuit board had snapped off. Also the button you press is damaged.
After a quick look on the internet I realised that a replacement cost about £150 :(
So I have managed to fix it by drilling a very small hole where the peg was & putting a very small screw in its place. The hole isn't exactly in the right place so the operation isn't perfect bu the window now can go down & more importantly up :D
Glad to have saved/postponed spending my hard earned cash :P
Tim
