No. 1 manifold stud
dom_e
No. 1 manifold stud
Post by dom_e » Wed Jul 24, 2013 8:47 pm
Ours has just failed. It began shortly after having the alternator, aircon and other (water pump?) belts changed and manifests as a whistle noise under load. It's not too bad, but we're going to be doing some big miles before it can be fixed. Is there an estimated time/mileage before it starts to become a noisy, unbearable sound?
I've been told it's about £150 to sort out if it's not too difficult to removed the sheered bolt. Realistic?
Cheers.
Dom
Beyond A to B
Re: No. 1 manifold stud
Post by haydn callow » Thu Jul 25, 2013 6:54 am
Sounds about right but I would fix it ASAP......you may find you are
' burning ' away metal or the gasket and that will make the job a bigger one.......I did mine in about 90 mins without removing anything. Just removed the broken stud, screwed in a bit of new stud and tightened it all up.......all was still o.k. A year later when I sold that one.
winchman
Post by winchman » Thu Jul 25, 2013 8:55 am
I agree get it done now, with the correct tools it should be removable easily
hembramacho
Post by hembramacho » Thu Jul 25, 2013 9:37 am
Get it done as soon as you can. We've had 2 go - first one pretty simple job to drill old one out and replace.
Second time, a whole lot more needed to be done, with replacement manifolds, gaskets, etc. needed.
Andrew
dom_e
Post by dom_e » Thu Jul 25, 2013 12:27 pm
Sadly, I've run out of time to get it fixed since I'm in work all day, then off in the eve. Is there anything I could do to prevent the problem worsening whilst we're away (dare I say, botch fix)?
I read some excellent instructions on how to dissemble, check and re-fit the manifold, but alas, time doesn't permit and the local Bongo garage can't fit it in today.
edit - I may try to duck out a bit early and take a look to see if it's possible to remove the broken stud without taking half the turbo etc. off, then get it to a garage for a replacement stud.
Beyond A to B
David Edwards
Post by David Edwards » Thu Jul 25, 2013 2:27 pm
I would shop about, my local garage did mine for 50 quid. They said it was easy,lol.
dom_e
Post by dom_e » Thu Jul 25, 2013 4:48 pm
I certainly will be then!
Beyond A to B
Post by haydn callow » Thu Jul 25, 2013 5:34 pm
Removing the stud is easy if you have the right tools.....you will need a carbide pilot drill and a bit of tube to centre it......then a drill of the correct size or try a stud extractor.....when stud removed.....helicoil or tap.....easy if you have everything to hand.....not a job to be rushed.....swing the alternator out of the way
Post by Northern Bongolow » Thu Jul 25, 2013 6:07 pm
the escaping exhaust gasses can overheat the alternator as the cooling fins/vents are opposite. #-o #-o .
it can also can make the passy seat a little warm to sit in for long distances, ask marianne at bongo fury HQ. she had a rump that was cooked to perfection, mmmmmmmm. :lol: :lol:
dom_e
Post by dom_e » Thu Jul 25, 2013 10:33 pm
Argh. All this is a bit worring now. I phoned around garages this afternoon, to no avail. The ferry is tomorrow am and there's no chance to sort it. Fan-bloomin' tastic timing on it happening! I can't find any reasonable price breakdown cover as well!
No option but to hope now! We've already driven to Reading from Cardiff for an overnight stop at relatives and it's a bit noisier than when we started.
Beyond A to B
Post by Northern Bongolow » Thu Jul 25, 2013 10:52 pm
its a long shot but you could try a big hand full of exhaust assembly paste over the entire area, and keep checking regularly.
dom_e
Post by dom_e » Thu Jul 25, 2013 10:58 pm
There is a Halfrauds on-route; could be worth a punt. If not before, I'll have time to do it on the ferry.
Beyond A to B
mulshy
Post by mulshy » Fri Jul 26, 2013 12:20 am
Our gasket went as we headed off on holiday a couple of years ago :evil:
We still carried on to John O Groats and around the north of Scotland a
good few hundred miles with only the embarrassment of a loud screech
echoing up the glens when going uphill to put a damper on our holiday.
Still had great time though 8)
When we got home and eventually stripped it down I found previous
owners had covered the already broken stud with exhaust putty which
had lasted a good few months.
Hope all goes well with your holiday!
all the same but different
dom_e
Post by dom_e » Fri Jul 26, 2013 7:00 am
Thank you all for the replies. One last question....I presume that the manifold is covered by a heat shield. Is this typically easy to remove to gain access and apply paste? I stupidly didn't pack spanners, but could buy a set.
Beyond A to B
Post by Northern Bongolow » Fri Jul 26, 2013 10:01 pm
no1 (broken ) stud isnt under the heat shield, its next to the alternator.
check out this link it will help a little.
http://igmaynard.co.uk/bongo/forum/view ... ifold+stud
