fluid leak
Colin H F
fluid leak
Post by Colin H F » Fri Jul 19, 2013 10:39 am
hi guys, just noticed a patch of fluid 0n the flags under the van 2.0 litre petrol, its about a foot in and centre of the side sliding door, I can see a sump just before the prop shaft,
Re: fluid leak
Post by Muzorewa » Fri Jul 19, 2013 10:50 am
Is it coolant or transmission fluid? could be either there. The coolant comes back to the rear heater matrix and the transmission sends the oil forward to the cooler, all the pipes are close together.
Colin H F
Re: fluid leak
Post by Colin H F » Fri Jul 19, 2013 11:18 am
Hi Muz just popped my head under the opposite side from the sliding door and i can see what you are referring to, i'll have to get it jacked up to see properly and when the suns not so bright, at least i know know where to start looking cheers mate, hope your keeping well, Colin
Re: fluid leak
Post by Muzorewa » Fri Jul 19, 2013 11:24 am
You say a foot in, from the driver's side or passenger side? If it's the passenger side it'll be a coolant leak, if it's the driver's side it could be either :wink:
lazyb5
Re: fluid leak
Post by lazyb5 » Fri Jul 19, 2013 1:01 pm
Have you had the aircon on in this weather, all aircons will drain onto the floor under the car.
