Hold light
greengaz
Hold light
Post by greengaz » Mon Jul 08, 2013 8:10 am
Hi all, Still got a problem with the flashing "hold" light on my n reg Bongo. I have bought a lead and have plugged it into 3 different diagnostics readers, No joy. I have jumped wires in the diagnostics socket and got a flashing code of ; 1 long flash,6 short, 6 long, 2 short,9 short flashes. Any help would be appreciated with this as I am waiting to go to France in it.
Thanks, Gaz
Re: Hold light
Post by mikeonb4c » Mon Jul 08, 2013 8:19 am
You'll probably need a specialist. Whereabouts are you?
Re: Hold light
Post by Doone » Mon Jul 08, 2013 8:58 am
greengaz
Re: Hold light
Post by greengaz » Mon Jul 08, 2013 1:37 pm
Hi Mike I am in wolverhampton.
Any help would be much appreciated.
Cheers Gaz
mikeWalsall
Re: Hold light
Post by mikeWalsall » Mon Jul 08, 2013 1:55 pm
I have had this guys card pushed under my wiper blades when parked both in Bilston and Wolverhampton .. I've never used this company or know anything about them .. maybe give them a try they may be able to help .. or know of a man who can ..
http://www.ebay.co.uk/itm/mazda-bongo-f ... 35c8a415a4
Only in Wednsebury so quite local ..
Dennis Eglington
Unit 6 Horton Place
Wednesbury
West Midlands
ws10 8hg
United Kingdom
Phone:07850|870145
Re: Hold light
Post by mikeonb4c » Mon Jul 08, 2013 5:40 pm
greengaz wrote:Hi Mike I am in wolverhampton.
Cheers Gaz
Might be worth phoning Ian Taylor (can't remember if he's Market Drayton or Stoke on Trent these days) to see is he could recommend someone or take a look himself. He's very good and a Bongo expert. Good luck - keep us posted.
greengaz
Re: Hold light
Post by greengaz » Mon Jul 08, 2013 6:17 pm
Thanks to all for the suggestions, I have had a poke around with a few connections, and at the moment its working like it should. I don't know for sure if I have done anything. Would this mean its likely to be a contact problem? or could it be more serious even though its working at the moment?
Any suggestions appreciated even if its to eliminate any problem.
Cheers guys G.
mikeWalsall
Re: Hold light
Post by mikeWalsall » Mon Jul 08, 2013 6:55 pm
I had a similar situation with my ABS light ..
It seems fine know .. the final solution seems to have been a multi pin plug not fully 'clicked' in ..
