enging not starting
matt whu
enging not starting
Post by matt whu » Sat Jun 29, 2013 10:16 pm
help just changed fuel filter re started engine ran for a while then stopped. took filter off again no fuel in filter any ideas :?:
Re: enging not starting
Post by haydn callow » Sat Jun 29, 2013 10:33 pm
Did you fill the new filter with fuel before fitting?
Driver+Passengers
Post by Driver+Passengers » Sat Jun 29, 2013 10:56 pm
If your fuel filter body does not have a primer pump on the top (lots don't), then it can take a full minute or more of cranking to start with a dry filter. Filling with fuel first should reduce the time.
Image Image
matt whu
Post by matt whu » Sat Jun 29, 2013 11:00 pm
haydn callow wrote:Did you fill the new filter with fuel before fitting?
no ,have change filter many times befor and never filled with fuel befor
Post by Simon Jones » Sat Jun 29, 2013 11:23 pm
Diesel or petrol? If the former, keep spinning it over on the starter and assuming you don't have a leak around the filter seal, it should eventually start. If petrol, turn ignition on and off a few times to allow the fuel pump to repressurise the fuel lines.
matt whu
Post by matt whu » Sun Jun 30, 2013 12:58 pm
Simon Jones wrote:Diesel or petrol? If the former, keep spinning it over on the starter and assuming you don't have a leak around the filter seal, it should eventually start. If petrol, turn ignition on and off a few times to allow the fuel pump to repressurise the fuel lines.
put disel in filter now runs should have known better
Post by Simon Jones » Sun Jun 30, 2013 6:49 pm
I guess you have a diesel engine then :wink:. Glad it's all sorted now. For next time, fill the empty filter with some injector cleaner to give the system a good clean out when it starts up.
