Finally got around to fitting the new rubber pipes after having them for best part of a year
http://www.advancedfluidsolutions.co.uk ... 2286-p.asp
thoughts please
I wouldn't bodge it mate. A new head is £2000. Do it proper with genuine parts.Timster2005 wrote:Hey Phil, how did you get on?
Reason for asking is that I've just found the exact same thing on the pipe to the rear heater on our poor old Bongolina, and was wondering whether some tee piece DIY thingy would do the trick.
There has been a small-ish leak there for a few months which I couldn't face looking at because of the cold weather. Gave it a prod tonight, and it turned into a flood.
I may have to bodge it temporarily with some epoxy putty thing (which I think has been used there before looking at the amount of goop that I had to wipe off), but that won't last long.
Any advice greatly received...
Cheers, Timster.
Cheers, Timster.
Timster2006 wrote:Hi Phil again (sorry, new account, old one got messed up),
my temporary epoxy bodge worked, but now it's time to do it properly as still dripping a bit.
My question is, what are the size (internal/exernal diameter) of those coolant pipes? And what size is the straight rubber hose that is needed to connect the tee piece to the old pipe?
I thought I'd found all the bits I needed last month, but it all seems to haev got lost in the mists of time.
Cheers, Tim.
I had to carefully cut the old pipes to get them off the stubs making sure not to scratch the stub as it could make it leek.yorkee wrote:Hi,
just wondering if anybody has changed the small bore metal coolant pipes under the front seats? I bought the three of them along withe the 12 other hoses and clips from my local Mazda dealer and wondered if there are any hints or tips before I tackle the job.
Many thanks.
