Battery terminals with take-offs
helen&tony
Post by helen&tony » Thu Apr 18, 2013 7:30 am
Does anyone have details of a positive battery terminal with additional terminal tags / bolts for accessories?
turbodave
Re: Battery terminals with take-offs
Post by turbodave » Thu Apr 18, 2013 7:56 am
Post by teenmal » Thu Apr 18, 2013 9:31 am
Hi,why not use a small # way fuse box.?
helen&tony
Post by helen&tony » Thu Apr 18, 2013 9:42 am
hi
Turbodave...
Thanks, I've looked at Conrad before, and despite their claims,they only post to 2 or 3 EU countries....That's a pity, as they have some stuff I can use!
Teenmal...
Yes...best idea!...I have a fusebox all ready to fit... :lol: :lol: :lol: ...BUT...I have some high-amp stuff I'd like to connect direct...I'm sure I've seen a battery terminal with an array of several bolts on a bar, but can't remember where! :-k
Post by teenmal » Thu Apr 18, 2013 9:46 am
helen&tony wrote:hi
Turbodave...
Teenmal...
If you put a longer bolt through the clamp and use an additional nut you will be able to connect the National Grid to it.
:D
Post by teenmal » Thu Apr 18, 2013 10:11 am
You could also try here,the trusty old Halfords :lol: ..
http://www.halfords.com/webapp/wcs/stor ... yId_255205
tallbongo
Post by tallbongo » Thu Apr 18, 2013 10:40 am
Or ebay... http://www.ebay.co.uk/itm/2-Heavy-Duty- ... 27d0900645
Others are available, but this was the first I saw with worldwide shipping.
95 N Reg 4WD Manual AFT Bongo
Image Image
helen&tony
Post by helen&tony » Thu Apr 18, 2013 10:50 am
Maybe I'm being pernickety, but I already have 6 connections (fused) off the +ve..... :lol: :lol: :lol: ...I need spares... :lol: :lol: :lol: ...some are getting transferred to a fuse box, but others NEED a terminal....I've seen the two-nut jobbies, but I'll swear i've seen 4 somewhere????....
I wonder how many batteries I can cram in the back?????? :lol: :lol: :lol: :lol: :lol: :lol:
Post by teenmal » Thu Apr 18, 2013 11:14 am
helen&tony wrote:Hi
Halfords advertise a 4 way terminal but it only shows an normal T in the pic it might be the wrong pic,you could ask them.
http://www.halfords.com/webapp/wcs/stor ... 55205#tab4
tallbongo
Post by tallbongo » Thu Apr 18, 2013 11:35 am
helen&tony wrote:Hi
With that many connections, perhaps you could look at adding a busbar instead.
Image Image
helen&tony
Post by helen&tony » Thu Apr 18, 2013 11:39 am
Looking at the links, it looks like they did use the wrong photos at Halfords ...maybe I'll look at the battery setup, and see if I can use that.
c1rider
Post by c1rider » Thu Apr 18, 2013 11:53 am
Could try Iveco. My Daily 2000 had a pressed steel clamp with multiple take-offs as standard
helen&tony
Post by helen&tony » Thu Apr 18, 2013 1:48 pm
I've just found what I want...Whoopee!!!...It's a distribution block with built-in cable outlets for heavy cable, jump-start outlet, and built in fuse box!!!!!
Just got to check if it's compatible with the Bongo fusible link
Post by teenmal » Thu Apr 18, 2013 2:09 pm
helen&tony wrote:Hi
Just got to check if it's compatible with the Bongo fusible linkCheers
Bit confused here,why does it need to be compatible with the fusible link if you are running direct from the pos terminal.
Cheers.
helen&tony
Post by helen&tony » Thu Apr 18, 2013 3:49 pm
The item replaces the original battery terminal entirely, and the original Mazda battery terminal has the small fusebox bolted directly to it...I reckon I'd need to see the box in the flesh, first, as I can't quite see how to replace the Mazda original fused systems in the new unit
