Seem to have developed a slight issue with the gear box if I set off steady all is well gears change as they should.
If I boot it the gears do not change up rev counter goes up to 3000 rpm and then it's like it hits a rev limiter.
Transmission oil level is ok.
Any ideas what to check before I go out and start to pull things apart ?
Gear change
Re: Gear change
I'm not techie, but is the throttle position sensor (TPS) a possible suspect? Maybe check out old threads on that one?
Re: Gear change
I had a touch of that recently and put it down to too much veg oil for this miserable climate.
Haven't noticed it since topping up a couple of times with diesel only.
Frank
Frank
They flew, I took up naturism
Re: Gear change
Problem solved thanks Diplomat just stuck a new fuel filter on and hay presto normal service is resumed.
Re: Gear change
try the great pretenders (mel) tip, he said some recent troubles along these lines and were down to a fuel tank pick up filter partly blocked, on his recommendation i tried it, and was quite surprised at the results.
i had no real issues, just the odd flat spot for a second when coming off the throttle and back on, thought it maybe turbo waste gate problem or tps etc.
sorted mine out just blowing back to the tank.
cheers mel.
cheers mel.
