v6 radiator fan switch
cheffy34
Post by cheffy34 » Sat Mar 30, 2013 5:53 pm
Guys i gotta an issue my fans are not cutting in
What controlls them is it the engine temp sender??
This may explain why my radiator blew a pinprick hole and shot a 6ft water jet out of my grill catching a passerby that promptly looked up at a clear sky to see where the rain was coming from :roll:
Thanks Dar
cheffy34
Re: v6 radiator fan switch
Post by cheffy34 » Sat Mar 30, 2013 6:04 pm
Allso anyone know which fuse it is???
Post by teenmal » Sat Mar 30, 2013 7:14 pm
The fans are triggered by the ETC sensor,if you remove the connector the fans should kick in.The fuse is No2 30amp under the hood.
Post by g8dhe » Sat Mar 30, 2013 10:26 pm
Easiest way is turn on the Air Con that will tell the ECU to turn the Fans on for a quick check. The fuse is;
Post by teenmal » Sun Mar 31, 2013 2:51 pm
As Geoff has said,turn on the AC to check the fans,just remember that this will tell you that the fan is working not that the fan is not (faulty) working.
cheffy34
Post by cheffy34 » Mon Apr 01, 2013 12:52 am
Fans come on if you disconnect the sender unit so i suppose that denotes the sender is goosed?
Dar
