Letting off some steam!!
Hanksy
Post by Hanksy » Mon Mar 18, 2013 10:47 am
Hi All apologies as i know this must of been answered loads but i cant see a specific answer anywhere
My bongo burst a pipe yesterday the one that is under the drivers seat top of the engine and goes towards the front about 2" pipe so while its out of action i was going to flush out the cooling system
how would i do it i did see a makeshift "hose lock" to coolant hose adapter in here somewhere (but i cant find it again)
do i need to make one of these and then attach it to the engine (or lower pipe) and just run it until clear water comes out , i assume i need to run it long enough so the engine gets hot to open thermostat allow radiator flushing too
is there anything i need to know as to not knacker my engine up
In advance
Stu
Re: Letting of some steam!!
Post by Simon Jones » Mon Mar 18, 2013 2:06 pm
See my posts here & related links: http://igmaynard.co.uk/bongo/forum/view ... ilit=+Glue.
Don't have the engine running while attempting to flush the system, but as you have hoses disconnected, you should be able to get reasonable flow even with the thermostat closed.
Re: Letting off some steam!!
Post by Northern Bongolow » Mon Mar 18, 2013 9:08 pm
or check the 3 video.s on how to bleed a mazda bongo on youtube, they may help.
the more info you have on bleeding the better.
