Cool box 12v & 240V
Moderator: Muzorewa
hijimhere
Cool box 12v & 240V
Post by hijimhere » Sun Mar 17, 2013 6:18 pm
Having inherited a TC9-295 Weaco cool box with my Bongo I have found that the chill/cool works on 240 but it does not work on 12v. Has anyone been lucky enough to find a fix?
Re: Cool box 12v & 240V
Post by g8dhe » Sun Mar 17, 2013 6:26 pm
Have you checked for any fuses ?
Velocette
Post by Velocette » Sun Mar 17, 2013 6:30 pm
hijimhere wrote:Having inherited a TC9-295 Weaco cool box with my Bongo I have found that the chill/cool works on 240 but it does not work on 12v. Has anyone been lucky enough to find a fix?
Are you sure your 12V socket is delivering enough voltage? I threw out an outwell coolbox with the same fault (I thought) but the wiring to the rear socket was at fault. It would light uo an LED etc but it wouldn't run a tyre pump or a 100W Inverter. I rewired mine with heavier cable direct to the LB (via a fuse)
hijimhere
Post by hijimhere » Mon Mar 18, 2013 12:43 am
will check that out with meter and the fuse - the double cigar lighter has a light to indicate it's powered so perhaps not a fuse --thanks
Post by g8dhe » Mon Mar 18, 2013 10:53 am
No not the vehicle fuse, but the fuse in the 12v plug for the fridge itself, lots of the plugs house a fuse accessed by unscrewing the tip.
Velocette
Post by Velocette » Mon Mar 18, 2013 1:05 pm
g8dhe wrote:No not the vehicle fuse, but the fuse in the 12v plug for the fridge itself, lots of the plugs house a fuse accessed by unscrewing the tip.
Ah, the ones that melt :)
Velocette
Post by Velocette » Mon Mar 18, 2013 1:08 pm
hijimhere wrote:will check that out with meter and the fuse - the double cigar lighter has a light to indicate it's powered so perhaps not a fuse --thanks
Check the voltage when the coolbox is plugged in and switched on. mine would light LEDs in various pieces of equipment but if you plugged something hungry in the vlotage would drop significantly. It is a long run of cable and not very substantially sized..
Post by Simon Jones » Mon Mar 18, 2013 3:22 pm
Waeco CF18 compressor fridge wont run reliably from rear socket due to current limitations on the vehicle wiring, Try it on the front socket where there is a bit more oomph :)
