eco ground sheets
Moderator: Muzorewa
eco ground sheets
hello
i have seen on some campsites that they require the use of eco ground sheets in awnings.
i have heard that they are not good or waterproof? my awning does not have a sewn in ground sheet, so i can get both types of ground sheet, i am just not familiar with them
any advice, recommendations or anything else !!!!!
vicki
vicki
- mikeWalsall
Re: eco ground sheets
I would say that you will not be able to use a 'solid' ground sheet on many sites ... most stipulate that only 'breathable' ones can be used ...
I must say that I agree .. there is nothing worse than seeing large patches of yellow grass after a long term pitch ..
mikeWalsall wrote:I would say that you will not be able to use a 'solid' ground sheet on many sites ... most stipulate that only 'breathable' ones can be used ...
Hi mike,I put my drive away awning up to air on the lawn last year for about a week,I did not use any ground sheet.
When I took the awning down there was a big yellow patch of yellow grass where the awning had been ,what do you think caused this to happen.
Thanks.
lack of sun light
wonkanoby wrote:lack of sun light
Hi,thanks for the information,would that mean that the breathable ground sheet would not cure this problem
My gardener was not amused.
- Simon Jones
I think you'd need a transparent awning and groundsheet to ensure the grass stays green
any one got a recommendation for a good breathable groundsheet
size 2m x 2m
cheers vicki
size 2m x 2m
cheers vicki
- the1andonly
- Tribal Elder
Eco ground sheets are not waterproof and in the past after 16 days holiday the grass had grown through and trapped the sheet in place, it needed teasing up.
As to sourcing them most caravan shops have a variety of sizes, though typical caravan awnings are at least 8 foot 2.4m wide.
We now have 2 awnings (side and tail) for the Bongo both with sewn in groundsheets, are these no longer permitted?
http://www.camperlands.co.uk/eco-mat-br ... sheet.html i,ve had mine for years and it has stood up too some hassle -it isnt waterproof it has big square holes in it so if you walk on it on soggy ground in socks you will get wet feet -on the other hand it drains off quickly without having to be removed or dried off with towels,its nice to walk on, its easy to cut to size and it isnt slippy when wet unlike old fashioned ground sheets -we used to just put anything that needed to be kept bone dry in one of those supermarket trolley bags.
Thats a good price,mine cost £23..... 6 yrs agokarena wrote:http://www.camperlands.co.uk/eco-mat-br ... sheet.html i,ve had mine for years and it has stood up too some hassle -it isnt waterproof it has big square holes in it so if you walk on it on soggy ground in socks you will get wet feet -on the other hand it drains off quickly without having to be removed or dried off with towels,its nice to walk on, its easy to cut to size and it isnt slippy when wet unlike old fashioned ground sheets -we used to just put anything that needed to be kept bone dry in one of those supermarket trolley bags.
Brian
