Leisure Battery Charging problem
Moderator: Muzorewa
Glenda
Post by Glenda » Fri Feb 15, 2013 3:54 pm
Ok. Last month the Bongo forum sorted out my Willinton split charge relay problem and I duly had a new one sent by Martin Willinton. Tomorrow a friend is fitting it. At present the central locking, wing mirrors, rear cig socket, radio, cd and clock are not functioning. I took out the Numax 110 leisure battery today to give it a charge with my CTEK charger ready for tomorrow. BUT after 6 hours it still has got no juice at all. It is only 4/5 years old but has been flat for 6 weeks now.
Is it kaput?
Re: Leisure Battery Charging problem
Post by g8dhe » Fri Feb 15, 2013 3:58 pm
If its been used a lot in the 4/5 years I would have thought it would be getting on in life and about to retire ;-)
But if was really flat 6 hours is nothing, you need to give it a good 48 hours, at least.
Glenda
Post by Glenda » Fri Feb 15, 2013 4:47 pm
Thanks. I will be more patient. i just found the ctek guidelines and apparently the charger flashes if battery is dead.It states 48 hours as charge time for 110 amps. So fingers crossed.
Dodgey
Post by Dodgey » Fri Feb 15, 2013 6:14 pm
I would have expected results after 6 hours but as its been flat for 6 weeks it will be very poorly. It might not even recover. Only time will tell. If the ctek has a good desulpharion phase like an optimate does then it should bring it back to life, even if it doesn't quite perform as it used to.
Which ctek charger is it? 6 hours at a few amps is quite a lot of charge, maybe it's just a trickle charger?
dobby
Post by dobby » Sat Feb 16, 2013 12:19 am
I'm about to get my third one in 8 years, lead acid is a very ancient technology :(
alan
Post by alan » Sat Feb 16, 2013 8:59 am
we still on ours 1st L/B its coming up 5/6years now
take it easy drive a bongo
Glenda
Post by Glenda » Sat Feb 16, 2013 10:08 am
Good news. The half charged light came on over night. I am expecting a full recovery Numax are a heavyweight leisure battery. Just 24 hours to go! Its a trickle charger and conditioner CTEK 3600.
dobby
Post by dobby » Sat Feb 16, 2013 8:06 pm
Great news Glenda
alan wrote:we still on ours 1st L/B its coming up 5/6years now
Alan - what makes yours? Do you use your bongo every day? I think my problem is that the bongo only gets used every couple of weeks?
alan
Post by alan » Sat Feb 16, 2013 8:50 pm
dobby wrote:Great news Glenda
11o amp wetline leisure marine that all i could see on it.
yes van runs most days so bat all ways topped up
dobby
Post by dobby » Sat Feb 16, 2013 8:54 pm
Cheers Alan, guess I need to get out more!
alan
Post by alan » Sat Feb 16, 2013 9:14 pm
dobby wrote:Cheers Alan, guess I need to get out more!
want about a small solar panel sat on your dash to a charge to LB :idea:
it save having to pulg it in ie wire from under the dash
dont know if these are any good but some think like it i was thinking
http://www.ebay.co.uk/itm/Brand-New-4W- ... 5d3a64d295
http://www.ebay.co.uk/itm/12v-Solar-Pan ... 3f1ded06a7
dobby
Post by dobby » Sat Feb 16, 2013 9:56 pm
Cheers, I've got one of those from Maplins guess I should start using it #-o
wonkanoby
Post by wonkanoby » Sun Feb 17, 2013 10:43 am
It prevents your car battery from becoming dead, which happens often when your car is left in the garage for
weeks.
his must have big windows
Dodgey
Post by Dodgey » Sun Feb 17, 2013 10:54 am
If your fag socket is wired to the leisure battery, which it will be with a Willington kit, the you can plug a small panel into it and pop it on the dash. It won't provide enough power to run appliances but it will keep your battery topped up when you are parked up.
