Leisure Battery Charging problem
Moderator: Muzorewa
Ok. Last month the Bongo forum sorted out my Willinton split charge relay problem and I duly had a new one sent by Martin Willinton. Tomorrow a friend is fitting it. At present the central locking, wing mirrors, rear cig socket, radio, cd and clock are not functioning. I took out the Numax 110 leisure battery today to give it a charge with my CTEK charger ready for tomorrow. BUT after 6 hours it still has got no juice at all. It is only 4/5 years old but has been flat for 6 weeks now.
Is it kaput?
Is it kaput?
Re: Leisure Battery Charging problem
If its been used a lot in the 4/5 years I would have thought it would be getting on in life and about to retire
But if was really flat 6 hours is nothing, you need to give it a good 48 hours, at least.
Thanks. I will be more patient. i just found the ctek guidelines and apparently the charger flashes if battery is dead.It states 48 hours as charge time for 110 amps. So fingers crossed.
I would have expected results after 6 hours but as its been flat for 6 weeks it will be very poorly. It might not even recover. Only time will tell. If the ctek has a good desulpharion phase like an optimate does then it should bring it back to life, even if it doesn't quite perform as it used to.
Which ctek charger is it? 6 hours at a few amps is quite a lot of charge, maybe it's just a trickle charger?
I'm about to get my third one in 8 years, lead acid is a very ancient technology
we still on ours 1st L/B its coming up 5/6years now
take it easy drive a bongo
Good news. The half charged light came on over night. I am expecting a full recovery Numax are a heavyweight leisure battery. Just 24 hours to go! Its a trickle charger and conditioner CTEK 3600.
Great news Glenda
Alan - what makes yours? Do you use your bongo every day? I think my problem is that the bongo only gets used every couple of weeks?alan wrote:we still on ours 1st L/B its coming up 5/6years now
11o amp wetline leisure marine that all i could see on it.dobby wrote:Great news Glenda
yes van runs most days so bat all ways topped up
Cheers Alan, guess I need to get out more!
want about a small solar panel sat on your dash to a charge to LBdobby wrote:Cheers Alan, guess I need to get out more!
it save having to pulg it in ie wire from under the dash
dont know if these are any good but some think like it i was thinking
http://www.ebay.co.uk/itm/Brand-New-4W- ... 5d3a64d295
http://www.ebay.co.uk/itm/12v-Solar-Pan ... 3f1ded06a7
alan wrote:want about a small solar panel sat on your dash to a charge to LBdobby wrote:Cheers Alan, guess I need to get out more!![]()
Cheers, I've got one of those from Maplins guess I should start using it
It prevents your car battery from becoming dead, which happens often when your car is left in the garage for
weeks.
his must have big windows
weeks.
If your fag socket is wired to the leisure battery, which it will be with a Willington kit, the you can plug a small panel into it and pop it on the dash. It won't provide enough power to run appliances but it will keep your battery topped up when you are parked up.
