Raising roof
Gixermark
Raising roof
Post by Gixermark » Sun Jan 20, 2013 10:54 am
Lo
Just wanted to know if you lubricate the raising parts of the roof ( guides, pnumatic parts etc! ) and if so what do you use?
Thanks :wink:
Re: Raising roof
Post by Ian » Sun Jan 20, 2013 11:18 am
Use 3-in-1 bicycle chain lubricant.
Re: Raising roof
Post by mikeonb4c » Sun Jan 20, 2013 11:41 am
Ian wrote:Use 3-in-1 bicycle chain lubricant.
Our Bongomeister is a wonderfully old fashioned sort of chap :lol: :lol:
Lots of other alternative's suggested on here if you have a search, though smell apart, 3 in 1 sounds sensible.
Velocette
Re: Raising roof
Post by Velocette » Sun Jan 20, 2013 2:20 pm
I use GT 85 and do the sliding door channels and the tailgate struts and hinges with it the same time. Seems to work. I guess with the hinges they should be greased occasionally too. If I used grease on the door cnnels it would turn into fur balls because of the dogs! Does a bit anyway.
Poohbear
Re: Raising roof
Post by Poohbear » Sun Jan 20, 2013 4:34 pm
White lithium grease, it's what the professionals use on all door hinges and locks etc. Clean all the old grease off with WD40 and then apply new.
Gixermark
Re: Raising roof
Post by Gixermark » Sun Jan 20, 2013 7:47 pm
Thanks all
Re: Raising roof
Post by teenmal » Sun Jan 20, 2013 7:57 pm
Hi Gixermark ,most Struts do not need lubricated,you polish them with printer paper on similar until the paper is clear(no black marks on the paper).Try it and you will see what I mean.
Cheers.
