Sediment light
RobEvans
Sediment light
Post by RobEvans » Sun Jan 06, 2013 6:06 pm
Hi got in bongo today she started fine and seems to be running as normal, but the sediment light and battery light are still on on. Any ideas cheers in advance Rob
Re: Sediment light
Post by Ian » Sun Jan 06, 2013 6:31 pm
It means your alternator is on the way out.
westonwarrior
Re: Sediment light
Post by westonwarrior » Sun Jan 06, 2013 6:32 pm
seiment and battery light point to charging problems
could be alternator
RobEvans
Re: Sediment light
Post by RobEvans » Sun Jan 06, 2013 6:46 pm
Thank you very much for that cheers Rob
alan
Re: Sediment light
Post by alan » Sun Jan 06, 2013 8:41 pm
there some reading here about it things to check http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57782
take it easy drive a bongo
RobEvans
Re: Sediment light
Post by RobEvans » Sun Jan 13, 2013 12:05 pm
Just followed fact sheet in members area and was having readings of 11.6 no load and 10.7 with ac headlights and radio on. Will now remove and drop off alternator for reconditioning
chipvan
Re: Sediment light
Post by chipvan » Sun Jan 13, 2013 7:08 pm
will it come up with a code if wire is not pluged into filter?...
Re: Sediment light
Post by g8dhe » Sun Jan 13, 2013 9:41 pm
No neither the alternator/charge or sediment lights go thru the ECU they go direct to the console;
chipvan
Re: Sediment light
Post by chipvan » Sun Jan 13, 2013 10:18 pm
i pulled out my sediment power cable eariler to do some work and forgot to re connect,will it freek anything out?
Re: Sediment light
Post by Northern Bongolow » Sun Jan 13, 2013 10:40 pm
no, its only a float on-off switch.
chipvan
Re: Sediment light
Post by chipvan » Sun Jan 13, 2013 10:43 pm
Thanks mate
RobEvans
Re: Sediment light
Post by RobEvans » Tue Jan 29, 2013 6:15 pm
Alternator fitted and working correctly sediment and battery light gone . Happy days
alan
Re: Sediment light
Post by alan » Tue Jan 29, 2013 10:00 pm
Mulletman wrote:Alternator fitted and working correctly sediment and battery light gone . Happy days
=D> =D> =D>
chipvan
Re: Sediment light
Post by chipvan » Wed Jan 30, 2013 10:06 pm
result! =D>
RobEvans
Re: Sediment light
Post by RobEvans » Wed Jan 30, 2013 10:49 pm
Thanks and thanks for all the helpful hints made life so much easier well appreciated
