Sediment light
Sediment light
Hi got in bongo today she started fine and seems to be running as normal, but the sediment light and battery light are still on on. Any ideas cheers in advance Rob
- westonwarrior
Re: Sediment light
seiment and battery light point to charging problems
could be alternator
could be alternator
Re: Sediment light
Thank you very much for that cheers Rob
Re: Sediment light
there some reading here about it things to check http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57782
take it easy drive a bongo
Re: Sediment light
Just followed fact sheet in members area and was having readings of 11.6 no load and 10.7 with ac headlights and radio on. Will now remove and drop off alternator for reconditioning
Re: Sediment light
will it come up with a code if wire is not pluged into filter?...
Re: Sediment light
Re: Sediment light
i pulled out my sediment power cable eariler to do some work and forgot to re connect,will it freek anything out?
Re: Sediment light
no, its only a float on-off switch.
Re: Sediment light
Thanks mate
Re: Sediment light
Alternator fitted and working correctly sediment and battery light gone . Happy days
Re: Sediment light
Mulletman wrote:Alternator fitted and working correctly sediment and battery light gone . Happy days
Re: Sediment light
result!
Re: Sediment light
Thanks and thanks for all the helpful hints made life so much easier well appreciated
