tent fixing threads
Moderator: Muzorewa
gozza
tent fixing threads
Post by gozza » Tue Dec 18, 2012 12:43 pm
I have several threads that need reparing where the tent attaches to the top, the boss with the thread in has pulled out in seceral places! I intend to take toe top off repair the bamage with Arldite and drill new holes for the screws to tap into. Has anyone had this problem any advice would be helpfull. Many thanks.
Gozza
Re: tent fixing threads
Post by g8dhe » Tue Dec 18, 2012 1:05 pm
Yup, its a common problem see here http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=31554
Watch out when you attempt to undo the screws they use Loctite on the threads so a strong constant torque on the screw is needed, so make sure you use the correct screwdriver and rather than jerking it keep up a constant pressure until they start to turn. Also worth trying to wedge each boss in place whilst the araldite sets to make sure its really well home in the hole! I used some garden canes last time around, trimmed to length as needed.
gozza
Post by gozza » Wed Dec 19, 2012 11:02 pm
Many thanks thats very helpfull will give it a go when weather gets a bit warmer. :D
Dodgey
Post by Dodgey » Sat Dec 22, 2012 3:49 pm
Aye - araldite works a treat
lancyman
Post by lancyman » Sat Dec 22, 2012 5:40 pm
I used araldite. It was a really easy.
