Well, decided Purple Pixie needed an oil change....
Read the factsheets on oil types and how to change a filter and do an oil change and....
Discovered the oil collection container I had would just slide under the plastic guard under the van without jacking it up - eyeballed it in place down through the engine bay
Discovered the sump plug was finger tight! (this follows on logically from the loose spark plug) the seller of our Bongo should employ more itinerant service crew.... we had a bloke called Finger Tight Malcolm http://www.dummett.net/ime/website/ime/ ... lcolm.html in Mini circles who once fitted a flywheel lock nut (150 lb/ft) ... finger tight.... it fell off, and used a 1p as a spacer in a front suspension unit... the wheel fell off
The oil came out as it always does regardless of how you do it.. 95% captive 5% on the drive, rags helped not to splash out of the filter though.....
New sump plug and washer (thanks Ian) put in place with circa 40 NM of torque (with a torque wrench... I once stripped a mini sump plug (steel plug in alloy threaded sump )
Then Filter in place hand tight (thank you Ian)
Oil went in by the litre ( 4of via Helens 1 litre pyrex jug - now in the dishwasher on INTENSIVE) used a coolant funnel to fill the engine but the use of a jug with more of a spout might have saved a few splashes.... sadly I had only 2 part containers of halfords 10/40 semi-synthetic left over from when my Mini engine used thin oil, I could have glugged in 4l straight out of a new can via its built in spout.... far easier
Then nail biting bit..... hoping the oil pressure ( aka lack of pressure <5psi) light goes out..... it did
Tomorrow, check oil level / check water level / put a nice little DYMO LETRA TAG label somewhere "oil change due xxxxxxx"
Will open the filter and have a better look at the used oil (brown and opaque) tomorrow
Pip Pip
Dr B
- Board index Bongo Fury Techie Stuff
- Search
- It is currently Wed May 27, 2026 12:49 am
- All times are UTC+01:00
Experiences: first oil change on 2 litre petrol auto
- Purple Pixie
Post by Purple Pixie » Sat Dec 15, 2012 12:47 am
1999 Ford Freda - "Purple Pixie"
Jump to
- Using The Bongo Forum
- ↳ Terms & Conditions
- ↳ Guidance
- ↳ FAQs
- ↳ How to Contact Us
- Bongo Fury
- ↳ Techie Stuff
- ↳ Bongo Chat
- ↳ Breaking Bongos
- ↳ Admin & Club Matters
- ↳ Bongo Camping Equipment
- ↳ Pimp My Bongo
- ↳ Was It You?
- ↳ Off Message
- ↳ Group Buys
- ↳ Bargains!
- ↳ Small Ads
- ↳ Bongoing with Children
- ↳ Insurance
- ↳ Campsites
- ↳ Bongo Furry!
- ↳ Going Abroad
- ↳ Bongo Bash 2024
- ↳ Bongo Bash 2023
- ↳ Bongo Bash 2022
- ↳ Bongo Bash 2021
- ↳ National Bongo Day 2020
- ↳ Bongo Bash 2019
- ↳ Bongo Bash 2018
- ↳ Bongo Bash 2016
- ↳ Bongo Bash 2017
- ↳ Bongo Bash 2015
- ↳ Bongo Bash 2014
- ↳ Bongo Bash 2013
- ↳ Bongo Bash 2012
- ↳ Bulgaria 2011
- ↳ Bongo Bash 2011
- ↳ Bongo Bash 2010
- ↳ Bongo Bash 2009
- ↳ Poland 2008
- ↳ Bongo Bash 2008
- ↳ Bongo Bash 2007
- UK Groups
- ↳ Scotland
- ↳ North West
- ↳ Yorkshire & North East
- ↳ Wales/Cymru
- ↳ West Midlands
- ↳ East Midlands
- ↳ Eastern Counties
- ↳ London, Kent & Sussex
- ↳ South Wessex
- ↳ Devon & Cornwall/Kernow
- ↳ Rest of the West
- International Section
- ↳ International
- ↳ Ireland
