How much coolant (litres) and what sort do I need?
I plan to rinse through the whole system with clean water, before refilling with 50:50 coolant/water mix.
Thanks !!
Off the top of my head I think it is about 13L mixed. Red seems to be the preferred choice. I am going to use Halfords Pre diluted next time because I live in a hard water area and I think I reckoned on buying 4X4 litres. If you change type, make sure you flush all the old stuff out.Gripped wrote:Anyone?
Simon Jones wrote:Factsheet should answer your queries:
http://www.igmaynard.co.uk/bongo/member ... oolant.pdf
The capacity is 13 litres, but unless you use a compressor to blow all the liquid out the system, then you'll probably only get about 6 or 7 litres back in again.
