What is this for ??
Hanksy
What is this for ??
Post by Hanksy » Thu Sep 13, 2012 4:36 pm
hello can anyone tell what these connections are for ?
on mine they are unplugged but have a shorting wire in one of them, they are located on the RHS of the bonnet
Ta
looks like they should plug into here ......but what are they /??
thanks for any help
Re: What is this for ??
Post by g8dhe » Thu Sep 13, 2012 5:18 pm
That location can hold up to 4 relays, it looks like only two are mounted on yours (not un-usual);
I suspect that you have the manual air con controls and the Fog lamp is probably not using the loom in the normal way, and is probably the reason it has a link on the end of the cable.
dave_aber
Post by dave_aber » Thu Sep 13, 2012 5:20 pm
Those 2 relays are for the sidelights and the headlights.
If your sidelights and headlights are working OK, then check if there are cables actually plugged into those 2 relays.
There can be a further 2 relays there, which are for Front Fogs and something else I can't work out at the moment.
Do you have front fogs fitted? If you do, try pulling out that shorting link and see if they switch off.
Edit : Too slow - I was searching the BWM for that 4th relay!
Image...Image
321Away
Post by 321Away » Thu Sep 20, 2012 4:19 pm
those plugs are for the automatic lights system, you probably have a switch on the panel under the steering wheel, with them removed the side lights come on with the normal switch only not the auto system, as long as they work, it means the system has been removed and bypassed
Julian
