side door wont open
Pennycooks
side door wont open
Post by Pennycooks » Mon Aug 27, 2012 10:26 pm
we have a problem the side door will not open. The central locking seems to be working fine in that the knob is going up and down, but the door just wont open. I have banged it with a plastic mallet inside and out and nothing.silly question but is it linked to the electrics, could it be a blown fuse?? HELP PLEASE. :(
Re: side door wont open
Post by Northern Bongolow » Mon Aug 27, 2012 10:33 pm
take it for a spin round the block, over speed bumps is best.
if that doesnt work, inside towards the front edge, low down a big flat hand slap usually does the trick.
after that its the panel inside off, remove hard plastic trim, remove handle, remove card trim then look for the cable that comes from the back edge of the door, it fastens to the central locking bit, push this towards the front of the door.WATCH YER FINGERS. you will hear the lecky bit engage then it should be ok.
Pennycooks
Post by Pennycooks » Mon Aug 27, 2012 11:27 pm
THANKS VERY MUCH! I will give that a go tomorrow and see how we get on. thanks again Evelyn [-o<
Post by teenmal » Tue Aug 28, 2012 11:37 am
Just as a matter of interest,was the battery disconnected or flat before this problem problem occurred.
Cheers.
Pennycooks
Post by Pennycooks » Tue Aug 28, 2012 11:45 pm
yes we have had problems with the battery being drained, that is another problem i need to sort. I have had some success this evening though. We tried thumping it, tried disconnecting the battery, tried speed bumps. Nothing. Then i got down to the nitty gritty and took the inside panel off, I couldn't get the handle off, but i pulled the panel back and and took a thin lump of wood and pushed down on the gears, and after a while it freed up and now we have a functioning door. Had a beer to celebrate and i am now breathing a sigh of relief. thanks Everyone!!! :D
bonog
Post by bonog » Thu Sep 06, 2012 4:08 pm
Same happened to me when the battery went flat mid-door-closer-cycle.
You wanna buy DVD?
Post by Simon Jones » Thu Sep 06, 2012 8:52 pm
Glad you got there in the end. Info here on removing the door handle (in case you ever need it):
http://www.igmaynard.co.uk/bongo/forum/ ... le#p548483
sdsk
Post by sdsk » Fri Sep 07, 2012 9:08 am
We thought we had this problem when we couldn't get out of our bongo one morning. Eventually found that the little people had been playing with the child lock! :lol:
2001 Aero 2.0l JAL Skylift roof & K2 Campers Intrepid Rear conversion in Carbon Fibre
