Rear suspension rubber blocks
thedogsbollox
- Tribal Elder
Anybody got a picture of these in place as I dont think my Bongo has any.
Re: Rear suspension rubber blocks
Do you mean the Bump Stops,if so bolted on the chassis above the axle. 28-111B
http://lushprojects.com/bongopartsmk2/c ... f02.html#4
£36 plus vat from mazda, or try http://www.google.co.uk/url?sa=t&rct=j& ... 9g6c41wMAQ.
or make your own.
or make your own.
Hi thedogsbollox,
Dont discard the old BS plate and set screws,thes can be adapted to be used with alternative stops for a few squid.
Cheers.
Cheers.
I'd love to hear how others have made their own, adapted the baseplate for other models of rubber stops etc. Sounds like good factsheet material
i made mine out of these
http://www.ebay.co.uk/itm/RUBBER-D-SECT ... 500wt_1361
then there are things available.
http://www.ebay.co.uk/itm/ws/eBayISAPI. ... 208wt_1111
http://www.ebay.co.uk/itm/Rubber-Bumper ... 559wt_1111
Thanks Ady, fantastic, i'll take a look.Northern Bongolow wrote:i made mine out of these
these are originals tony, from vince,great family to deal with,
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 905wt_1344
thedogsbollox
- Tribal Elder
Well mine are definitely not there. So I think a bit of DIY is needed. I will of course take some photos. Any pointers, materials?
the plates that mount them will be there tony. unbolt them and use them as a template.
you can drill the plate and screw/glue any rubber block to it or.
i just got a piece of flat bar, get a measured piece of the D section rubber, thread the bar through, then bend steps into it then bolt up to the chassis.
this gives a nicer softer hit when on full load, but still does the job.
- helen&tony
Excellent stuff...but British Rail Pork Pies are quite good, if a little harder than standard rubber
