Rear suspension rubber blocks
thedogsbollox
Post by thedogsbollox » Sat Aug 25, 2012 2:12 pm
Anybody got a picture of these in place as I dont think my Bongo has any.
rita
Re: Rear suspension rubber blocks
Post by rita » Sat Aug 25, 2012 4:48 pm
Do you mean the Bump Stops,if so bolted on the chassis above the axle. 28-111B
http://lushprojects.com/bongopartsmk2/c ... f02.html#4
Post by Northern Bongolow » Sat Aug 25, 2012 5:21 pm
£36 plus vat from mazda, or try http://www.google.co.uk/url?sa=t&rct=j& ... 9g6c41wMAQ.
or make your own. 8)
rita
Post by rita » Sat Aug 25, 2012 9:35 pm
Hi thedogsbollox,
Dont discard the old BS plate and set screws,thes can be adapted to be used with alternative stops for a few squid.
Cheers.
Post by mikeonb4c » Sun Aug 26, 2012 8:40 am
I'd love to hear how others have made their own, adapted the baseplate for other models of rubber stops etc. Sounds like good factsheet material :-)
Post by Northern Bongolow » Sun Aug 26, 2012 10:33 am
Post by mikeonb4c » Sun Aug 26, 2012 10:40 am
Thanks Ady, fantastic, i'll take a look. :-)
Post by Northern Bongolow » Sun Aug 26, 2012 10:44 am
these are originals tony, from vince,great family to deal with,
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 905wt_1344
thedogsbollox
Post by thedogsbollox » Sun Aug 26, 2012 10:45 am
Well mine are definitely not there. So I think a bit of DIY is needed. I will of course take some photos. Any pointers, materials?
Post by Northern Bongolow » Sun Aug 26, 2012 12:46 pm
the plates that mount them will be there tony. unbolt them and use them as a template.
you can drill the plate and screw/glue any rubber block to it or.
i just got a piece of flat bar, get a measured piece of the D section rubber, thread the bar through, then bend steps into it then bolt up to the chassis.
this gives a nicer softer hit when on full load, but still does the job.
helen&tony
Post by helen&tony » Sun Aug 26, 2012 12:53 pm
Excellent stuff...but British Rail Pork Pies are quite good, if a little harder than standard rubber :lol: :lol: :lol: :lol: :lol:
