Hello everybody.
I am a new Bongo owner and would appreciate a bit of advice. I have read about faulty fuel gauges on here and the other bongo forum. My scenario is as follows :-
Fill bongo up with diesel :
Fuel gauge shows 3/4 full. It never reaches the full marker. Drive until fuel gauge shows empty. Then re-fill tank, it only takes 29.5 litres (290km-ish) and I believe our bongo's have a 65 litre tank. Unless someone has replaced my tank with a 30 litre tank!!!
Any ideas?
Thanks in advance for you time and knowledge.
Mark
Fuel Gauge/Tank Question/Issue
Re: Fuel Gauge/Tank Question/Issue
Hi and welcome to the forum, I had similar issues to you so did the re-earth tip and it now fully works.
- daveblueozzie
just follow these simple instructions, that fixes most faulty senders.
http://www.igmaynard.co.uk/bongo/forum/ ... uel+sender
Lost without my Bongo.
or just earth the tank edge from under the car to the chassis
ian at the bongo shop sells a little kit to do this if your struggling.
Thanks everyone for all your responses.
I will open up the panel and have a look before I attempt anything. I'm sure to be back with some photo's and questions. Will probably be next weekend. Having my 1st weekend away next weekend. Cant wait, me and my 2 sons!!!
Thanks Again.
Thanks Again.
If you do fine its the sender I have fixed on in the past its quite easy, just ask
