cutting out
coolerking76
cutting out
Post by coolerking76 » Thu Jun 14, 2012 4:45 pm
ok folks help needed again bongo has stared to cut out intermittently when coming to a stop and take a bit of time to get her going again any ideas .....thinking the fuel pump may be going faulty what do you think :?: [-o<
Re: cutting out
Post by g8dhe » Thu Jun 14, 2012 5:09 pm
A common problem is a vacuum forming in the fuel tank due to a blocked vent in the fuel cap, try releasing the cap, and running without it for a couple of journeys.
mikexgough
Re: cutting out
Post by mikexgough » Fri Jun 15, 2012 7:14 am
You don't say if your Bongo is petrol or diesel .....
Re: cutting out
Post by teenmal » Fri Jun 15, 2012 9:45 am
mikexgough wrote:You don't say if your Bongo is petrol or diesel .....
Diesel
321Away
Re: cutting out
Post by 321Away » Fri Jun 15, 2012 11:42 am
As Geoff said, fuel pump seal,and or blocked fuel cap breather, they work in tandem to make life difficult!! Run it without the cap, if the seal hasnt failed too much you'll be fine, but the point will come where it'll need replacing
Julian
mikexgough
Re: cutting out
Post by mikexgough » Sun Jun 17, 2012 5:20 am
as Julian says.... Fuel Pump seal(s) ....could also be an air leak at a joint too.... last resort problem is Pump failure...the internal rotors can wear out...which results usually in your symptoms BUT usually that also has a period of cut outs (usually soon after cold starts, normally when slowing down soon after cold start and ends with a cut out as if your fuel has run out and if...if you get restarted it will run on 3 cylinders etc...
coolerking76
Re: cutting out
Post by coolerking76 » Wed Jul 25, 2012 5:45 pm
Bit of an update , im very peed off with my bong :evil: had the fuel pump reconditioned seals changed ect, but since its been refitted the hold light is flashing ..dose anyone know if the throttle potentiometer may have been reassembled wrong to cause the problem. :?:
please help . im getting to the point of thinking about burning it out over the park :lol:
coolerking76
Re: cutting out
Post by coolerking76 » Wed Jul 25, 2012 5:48 pm
by the way its a n reg diesel
coolerking76
Re: cutting out
Post by coolerking76 » Wed Jul 25, 2012 6:38 pm
hold button dose not work at all
Re: cutting out
Post by teenmal » Wed Jul 25, 2012 10:12 pm
Hi coolerking76,
Did you remove and refit the IP before and after it was serviced or did the diesel shop do the full job.?
coolerking76
Re: cutting out
Post by coolerking76 » Wed Jul 25, 2012 11:15 pm
yeah, my local garage removed the pump and sent it away to be done
Re: cutting out
Post by teenmal » Wed Jul 25, 2012 11:34 pm
coolerking76 wrote:yeah, my local garage removed the pump and sent it away to be done
Hi,did your local garage refit and time the pump.?
Cheers.
coolerking76
Re: cutting out
Post by coolerking76 » Thu Jul 26, 2012 7:07 pm
yes that's right yes, he did, not really sure about timing though he never mentioned it :idea: it also chuggs and splutters when its been stood for a good while
do you think this may be related :?:
sorry if i sound dumb i only have a very small knowledge of engines :oops:
Re: cutting out
Post by teenmal » Fri Jul 27, 2012 9:27 am
Hi coolerking76,
I would take the vehicle back to your garage and ask them to have a look at it,it may need the IP timing and the TPS adjusted.
Good luck..
