diagram or photo
tboy
diagram or photo
Post by tboy » Thu Jun 14, 2012 2:58 pm
is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
Or on the passenger side below the alternator is a component with a pully on the front,but on mine it does not seem to be connected?
321Away
Re: diagram or photo
Post by 321Away » Thu Jun 14, 2012 3:11 pm
aircon compressor
julian
tboy
Post by tboy » Thu Jun 14, 2012 3:14 pm
321Away wrote:aircon compressor
julian
should there be a belt attached to the pully?
Post by g8dhe » Thu Jun 14, 2012 3:17 pm
You can find all the mechanical diagrams here select you version of the vehicle etc. first;
http://www.lushprojects.com/bongopartsmk2/
and the wiring diagrams for 1995 thru to 1999, but not post 2000 here;
Check out the Help pages and the Color codes as well!
321Away
Post by 321Away » Thu Jun 14, 2012 3:18 pm
yes, you should have 2 belts on the alternator, running around bottom (crank) pulley,water pump and alternator, in front of that shoul be a single belt running around (same)bottom pulley, then tensioner and aircon compressor
Julian
Post by g8dhe » Thu Jun 14, 2012 3:27 pm
Here you are the diagram http://lushprojects.com/bongopartsmk2/c ... mgno=.html
also very recent discussion regarding belts but for the alternator http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=56193
dave_aber
Post by dave_aber » Thu Jun 14, 2012 5:12 pm
tboy wrote:is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
Have a look here on the wiki.
Image...Image
