is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
Or on the passenger side below the alternator is a component with a pully on the front,but on mine it does not seem to be connected?
diagram or photo
Re: diagram or photo
aircon compressor
julian
julian
should there be a belt attached to the pully?321Away wrote:aircon compressor
julian
You can find all the mechanical diagrams here select you version of the vehicle etc. first;
http://www.lushprojects.com/bongopartsmk2/
and the wiring diagrams for 1995 thru to 1999, but not post 2000 here;
Check out the Help pages and the Color codes as well!
yes, you should have 2 belts on the alternator, running around bottom (crank) pulley,water pump and alternator, in front of that shoul be a single belt running around (same)bottom pulley, then tensioner and aircon compressor
Julian
Julian
Here you are the diagram http://lushprojects.com/bongopartsmk2/c ... mgno=.html
also very recent discussion regarding belts but for the alternator http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=56193
Have a look here on the wiki.tboy wrote:is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
