I need to replace the fuel return pipe from the injector rail to the pump, its a flexi and is only about 75mm ish long, but what bore pipe do i need 3mm 4mm 5mm ????????
Thanx, Pete.
Fuel pipes ?
Re: Fuel pipes ?
I seem to remember missfixit70 posting on this... I followed the advice a couple of years back? Scroll down...
http://www.igmaynard.co.uk/bongo/forum/ ... =fuel+hose
I did all mine on the flow & return... http://lushprojects.com/bongopartsmk2/c ... mgno=.html
I got two lengths of hose to the gauge of what Kirsty said & run new through... The hose wall on the new may be a tad thicker..?
Hope this helps!?
Hope this helps!?
Re: Fuel pipes ?
splill rail pipe?
