Fuel pipes ?
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Fuel pipes ?
Post by M 80NGO » Wed May 23, 2012 8:15 pm
I need to replace the fuel return pipe from the injector rail to the pump, its a flexi and is only about 75mm ish long, but what bore pipe do i need 3mm 4mm 5mm ????????
Thanx, Pete.
jaylee
Re: Fuel pipes ?
Post by jaylee » Wed May 23, 2012 9:26 pm
I seem to remember missfixit70 posting on this... I followed the advice a couple of years back? Scroll down... :wink:
http://www.igmaynard.co.uk/bongo/forum/ ... =fuel+hose
I did all mine on the flow & return... http://lushprojects.com/bongopartsmk2/c ... mgno=.html
I got two lengths of hose to the gauge of what Kirsty said & run new through... The hose wall on the new may be a tad thicker..?
Hope this helps!?
chipvan
Re: Fuel pipes ?
Post by chipvan » Thu May 24, 2012 8:25 pm
splill rail pipe?
