My bongo had no rear speakers when I got it. So thinking it would be easy I purchased some original speakers.
Wiring is there, have simply clipped it connectors expecting them to work they dont! Anyone have any ideas where um going wrong?
Cheers!
rear speakers
Moderator: Ian
nickbed
Re: rear speakers
You may have to check the back of the stereo to see how many speakers are feeding into it. The rears may just be a harness but not connected to anything. I assume you have checked if the speakers are working.
Re: rear speakers
I was in a similar spot.. Loom, no speakers in the back... But mine worked straight off when fitted.. (Though after market speakers.)
You sure you have the radio fader sending a signal to the back..??
They cant both be duff...
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: rear speakers
Have you altered your head unit balance to pick up the rear speakers ?
