radio/dvd was draining battery
antman
Post by antman » Wed Apr 25, 2012 4:56 pm
Hi All
My dashboard radio/dvd was draining 0.9amp's (so i'm told by an auidio electrician ) and was draining my SB. This was a fault in the radio/dvd player.
I would like a radio/dvd player that will work via the LB/Mains hook up as well as when driving as to not be soley off the SB.
Is this possible and any suggestions on radio/dvd around £100-£150?
or shoud I go for roof mount? again any recomendations?
thanks for your help :?
Re: radio/dvd was draining battery
Post by g8dhe » Wed Apr 25, 2012 5:33 pm
Yes! This sort of problem has been heard of before and is not the normal situation, however its difficult to be sure which makes / models are the cause of excessive current drain!
If you do a search like this one "fitting and dvd" and request Topics it will give you a list of all the discussions with those two words in it, there is a lot of discussion as its a common theme!
antman
Post by antman » Wed Apr 25, 2012 7:39 pm
Brilliant - many thanks :D
Dodgey
Post by Dodgey » Thu Apr 26, 2012 10:47 am
By the way - any stereo will work of the LB - it's just a matter of how you wire them up. Whether it will be powered by the hookup depends on whether your hookup wiring powers/charges the battery/12v circuit.
antman
Post by antman » Thu Apr 26, 2012 11:55 am
many thanks for that
longhaul8
Post by longhaul8 » Thu Apr 26, 2012 12:59 pm
I have my interior lights radio and blinds all from the lesuire battery.
That way i i stop at a pub and have a couple of drinks i can get in the back of the van and sleep it off and listen to the radio if i wish that way if the boys in blue come around the keys are not in the ignition so in theory not in control of the van while over the limit.
