New Shape 1999 V6 Idling Speed
Bainsy
Post by Bainsy » Mon Apr 02, 2012 10:22 am
How do you adjust the idling speed? Its a V6 new shape and has been converted to lpg. idles too fast on both lpg and petrol. Thanks for any advice.
Nigel
New Shape White over Silver V6 LPG JAL Side Conversion Mushroom Roof
Re: New Shape 1999 V6 Idling Speed
Post by Simon Jones » Mon Apr 02, 2012 1:11 pm
Is this on startup or when warm? It will run pretty fast when cold but should settle down once warmed up.
Bainsy
Post by Bainsy » Mon Apr 02, 2012 1:23 pm
It runs fast when warm - about 1300rpm in P or N and about 1000 in D
Nigel
Post by rita » Mon Apr 02, 2012 1:34 pm
Simon Jones wrote:Is this on startup or when warm? It will run pretty fast when cold but should settle down once warmed up.
Apparently it does it on LPG,it will be warm,sounds like it could be drawing air somewhere,(where it shouldn't)
Cheers.
apole
Post by apole » Tue Apr 03, 2012 10:53 am
Under the drivers seat, towards the rear of the inlet manifold is an air screw. This adjusts the tickover speed.
Circled in red:
http://i232.photobucket.com/albums/ee11 ... eScrew.jpg
Bainsy
Post by Bainsy » Tue Apr 03, 2012 4:52 pm
Thanks for your help
Nigel
Bainsy
Post by Bainsy » Wed Apr 04, 2012 10:18 pm
Have found it. To decrease idling speed which way do you turn it?
Nigel
Post by Simon Jones » Thu Apr 05, 2012 8:18 am
You've got a 50 / 50 chance :). Make a note of it's current position and turn it 1/4 turn one way an listen to the engine revs. If it goes up, then go back 1/2 a turn the other way and it should go down. If all else fails, stick it back in the middle.
apole
Post by apole » Thu Apr 05, 2012 10:02 am
Tightening it clockwise will decrease the revs. As Simon has said so long as you do things gradually in stages you can easily return to where it was.
Make sure the engine is fully warmed up before you change it, and then test it gear and with the AC on and off to be sure it settles in the best place.
I found setting it too low would cause it to stall when the AC kicked in and out, yes it compensates for the extra load but there was a slight delay in that happening.
I found mind worked best at around 750-800 RPM.
Bainsy
Post by Bainsy » Thu Apr 05, 2012 10:06 am
Thanks again for your help
Nigel
Bainsy
Post by Bainsy » Thu Apr 05, 2012 10:08 am
Did you mean 750 to 800rpm in Drive?
Nigel
Bainsy
Post by Bainsy » Thu Apr 05, 2012 10:48 am
Stupid question of mine noticed you already said in gear.
Nigel
Post by teenmal » Thu Apr 05, 2012 10:56 am
Hi you are looking for 750--800 RPM in neutral
Bainsy
Post by Bainsy » Thu Apr 05, 2012 5:47 pm
Have turned it clockwise a good half turn but made no difference. Is that normal?
Nigel
