New Shape 1999 V6 Idling Speed
How do you adjust the idling speed? Its a V6 new shape and has been converted to lpg. idles too fast on both lpg and petrol. Thanks for any advice.
Nigel
New Shape White over Silver V6 LPG JAL Side Conversion Mushroom Roof
Re: New Shape 1999 V6 Idling Speed
Is this on startup or when warm? It will run pretty fast when cold but should settle down once warmed up.
It runs fast when warm - about 1300rpm in P or N and about 1000 in D
Nigel
Simon Jones wrote:Is this on startup or when warm? It will run pretty fast when cold but should settle down once warmed up.
Apparently it does it on LPG,it will be warm,sounds like it could be drawing air somewhere,(where it shouldn't)
Cheers.
Under the drivers seat, towards the rear of the inlet manifold is an air screw. This adjusts the tickover speed.
Circled in red:
http://i232.photobucket.com/albums/ee11 ... eScrew.jpg
Circled in red:
Thanks for your help
Nigel
Have found it. To decrease idling speed which way do you turn it?
Nigel
You've got a 50 / 50 chance
. Make a note of it's current position and turn it 1/4 turn one way an listen to the engine revs. If it goes up, then go back 1/2 a turn the other way and it should go down. If all else fails, stick it back in the middle.
Tightening it clockwise will decrease the revs. As Simon has said so long as you do things gradually in stages you can easily return to where it was.
Make sure the engine is fully warmed up before you change it, and then test it gear and with the AC on and off to be sure it settles in the best place.
I found setting it too low would cause it to stall when the AC kicked in and out, yes it compensates for the extra load but there was a slight delay in that happening.
I found mind worked best at around 750-800 RPM.
Thanks again for your help
Nigel
Did you mean 750 to 800rpm in Drive?
Nigel
Stupid question of mine noticed you already said in gear.
Nigel
Hi you are looking for 750--800 RPM in neutral
Have turned it clockwise a good half turn but made no difference. Is that normal?
Nigel
