door mirrors not working
brianwfl
Post by brianwfl » Wed Mar 07, 2012 12:50 pm
Hi ther, my drivers side door mirror is not extending/retracting the motor runs but will not switch off unless slight pressurure applied then will shut off any ideas gratefully accepted.
brgds brianwfl
wonkanoby
Re: door mirrors not working
Post by wonkanoby » Wed Mar 07, 2012 1:42 pm
push it in and then pull it back to sere it should be......without motor running
sounds like its been clumped
jaylee
Post by jaylee » Wed Mar 07, 2012 9:32 pm
Is there slight play (about an inch) in aforementioned mirror, when opened out??
brianwfl
Post by brianwfl » Thu Mar 08, 2012 1:31 pm
Thanks for replies, mirror has not been clumped operated normally previously. parked o/night mirrors retracted. About 1/2 inch play. sounded like cogs jumped at tooth or cogs partially stripped.
thanks again]
brgds brien :)
jaylee
Post by jaylee » Thu Mar 08, 2012 10:38 pm
brianwfl wrote:Hi ther, my drivers side door mirror is not extending/retracting the motor runs but will not switch off unless slight pressurure applied then will shut off any ideas gratefully accepted.
brgds brianwfl
brianwfl wrote:Thanks for replies, mirror has not been clumped operated normally previously. parked o/night mirrors retracted. About 1/2 inch play. sounded like cogs jumped at tooth or cogs partially stripped.
thanks again]
brgds brien :)
There is a plastic spline on the (last?) cog in the gear mechanism to the drive from the motor. All the rest are metal but this one is plastic & part of the plastic moulding that houses the gears... Circled in red.. Its the weakest point.
This is the top part to the motor housing??
I fear it may have sheared loose...? I could be wrong..??!! But, if the mirror don't move & all you get is a whirring click click click..? :|
