Battery dead as dodo
flossie
Post by flossie » Sun Mar 04, 2012 10:54 pm
I be managed to drain the battery by leaving an interior light on for days - dead as dodo :(
What do I need to buy to replace it and approx how much will it be please ? I've not got an LB thank goodness so only 1 to replace !!
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
westonwarrior
Re: Battery dead as dodo
Post by westonwarrior » Sun Mar 04, 2012 11:11 pm
try giving it a charge
flossie
Post by flossie » Sun Mar 04, 2012 11:17 pm
I'm told by the camper an mechanic who lives next door I need a new one ( and no he isn't touting for business !)
Liz
Post by Northern Bongolow » Sun Mar 04, 2012 11:28 pm
did he test it.or is he just saying that without testing it.
i would give it a good charge and see what happens, you have nothing to loose, only £80 to gain. [-o< [-o< .
flossie
Post by flossie » Sun Mar 04, 2012 11:35 pm
What battery do I need to get please?
Liz
chipvan
Post by chipvan » Sun Mar 04, 2012 11:42 pm
charge it 1st..no need to say you need a new one if its flat due to loss of power.
you know why it when falt,it didnt go flat by itself..
Post by g8dhe » Mon Mar 05, 2012 12:02 am
This thread suggests several http://www.igmaynard.co.uk/bongo/forum/ ... 48#p539438
but it really isn't likely that the battery is actually dead or faulty, just from being totally discharged once in its life, it just needs a mains charger to be put on it for 48 hours and it will most likely come straight back quite happily! Worth asking locally if you can borrow a charger or drop a battery into a neighbour who has one.
fatcatlawyer
Post by fatcatlawyer » Mon Mar 05, 2012 12:04 am
Get a "jump Start" and then drive it for about twenty miles. Park it up over night and see if the battery is flat the next day. If it is = you need a new battery. For the right one do a search on here and you will get the model number of the battery. If you are in the AA or similar phone them and they will give you a jump start.
flossie
Post by flossie » Mon Mar 05, 2012 12:54 am
Thanks tried jump leads and nope not a glimmer :(
Liz
winchman
Post by winchman » Mon Mar 05, 2012 7:12 am
flossie wrote:Thanks tried jump leads and nope not a glimmer :(
It should start with jump leads. unless they are the thin ones?? Jump leads need to be thick cable usually as thick as your finger as the thin ones wont pass the large amount of electrical current required to start it.
As has allready been said, charge it up then test the battery as being flat shouldnt be a problem.
Our local motor factor will test the battery and charging system all for free.
Have you got a charger? Do you know how to charge it up? if not just ask and we can talk you through it.
Post by teenmal » Mon Mar 05, 2012 1:32 pm
flossie wrote:What battery do I need to get please?
If you need a battery,I can recommend this one..444773357 s4028 (£99.55) Enter discount code SERVICE25 then £74.65
http://www.eurocarparts.com/search/444773357/p/home.
flossie
Post by flossie » Mon Mar 05, 2012 2:27 pm
Leads were big fat ones that my friend has for her van and motor home ... Dad coming over later with a charger .., the panic is due to Crufts on Friday and Sat - HAVE to have the van sorted any other time it's no stress ( typical) ... will report back and thanks so much for advice so far
Liz
froghandler
Post by froghandler » Mon Mar 05, 2012 9:56 pm
It really is worth trying to charge it over a couple of days, tho I appreciate your urgent need for it.
I managed to let the battery go totally flat on mine and jump starting from the OHs discovery gave no joy either. Thought I was going to have to get a new one but I stuck it on charge for a couple of days, put it back in and lo and behold the bongo started up sweet as anything on the first turn of the key. :D
gasace
Post by gasace » Tue Mar 06, 2012 7:57 am
Both my batteries were drained when a relay stuck, on keeping the split charge relay open and the heater fan on for a week. The garage started the bongo with a huge boost battery, and then slowly charged both batteries. All is well with the batteries a year later, but we never found what caused the fault.
