There's a t shape pipe on the drivers side middle of the van one of the pipe drips when running hot pipe is held with a jubilee clip that will not tighten up any more do I need a new pipe or just jubilee clip if I undo clip will coolant go everywhere hope some
One can give me some advise before I go and make a mess of my bongo
Coolant leaking dripping when hot
2manymadmonkeys
- Bongonaut
Re: Coolant leaking dripping when hot
most peeps just double clip it then remove/replace the broken clip with a new one so you end up with 2 new clips on.
jubilee clips should not really be used as you will be doing this every couple of months,use the proper mazda clips.
- haydn callow
or use NORMA constant pressure clamps....google them !!
