Electric nearside mirror
JonWM
Post by JonWM » Mon Feb 20, 2012 11:27 pm
My offside mirror can be adjusted and power folded from the switch in the car but the nearside one can't - nothing can be adjusted at all.
Where's a good place to start to look for the fault, please?
Jon
Second bongo
White and Silver T reg AFT with Montague conversion
Re: Electric nearside mirror
Post by Bob » Mon Feb 20, 2012 11:38 pm
Look for broken wires where the loom passes from the A pillar to the door, assuming you've moved the little slider switch that controls which mirror you're adjusting.
Good luck. :)
JonWM
Post by JonWM » Mon Feb 20, 2012 11:46 pm
Thanks Bob.
Slider switch? :D yep tried that thank you 8)
It looks like the mirror may have had a knock cos its a bit wobbly where it is attached to the car. Will look at the loom tomorrow.
Jon
Second bongo
Post by Northern Bongolow » Tue Feb 21, 2012 4:59 am
grab the whole head and push fully forward and fully back it may relocate into the mechanism then and be ok.
it will make a few unnerving noises but it should be ok. #-o [-o< [-o<
