My offside mirror can be adjusted and power folded from the switch in the car but the nearside one can't - nothing can be adjusted at all.
Where's a good place to start to look for the fault, please?
Electric nearside mirror
Jon
Second bongo
White and Silver T reg AFT with Montague conversion
Second bongo
Re: Electric nearside mirror
Look for broken wires where the loom passes from the A pillar to the door, assuming you've moved the little slider switch that controls which mirror you're adjusting.
Good luck.
Good luck.
Thanks Bob.
Slider switch?
yep tried that thank you
It looks like the mirror may have had a knock cos its a bit wobbly where it is attached to the car. Will look at the loom tomorrow.
Slider switch?
Jon
Second bongo
Second bongo
grab the whole head and push fully forward and fully back it may relocate into the mechanism then and be ok.
it will make a few unnerving noises but it should be ok.
